Motorcycle Photography
  • Tutorial Motorcycle Photography
    This is a 1974 Yamaha FS1E, shot in a similar manner to the first image. The lighting hadn't changed, but I found the tank and side panel appeared brighter in the teat shot, so increased the aperture to F7.0
    Olympus E-M1 mkII 1/250th sec 12-40mm F2.8 @ F7.0 ISO64, 200 & 400
    The final bike is a 1970 Honda CT70, which were fondly referred to as Monkey bikes in my youth. I found I had to increase the aperture by a third again, bringing it to F8. The light locations and output remained the same, and I used the same three exposure bracketed technique to create the final image.
    Olympus E-M1 mkII 1/250th sec 12-40mm F2.8 @ F8 ISO64, 200 & 400
    This is a pull back, showing the effect of the pooled light around the bike
    Olympus E-M1 mkII 1/250th sec 12-40mm F2.8 @ F8 ISO200
    And this is the same scene, shot under programmed mode to give a better idea of the work area and lighting setup. The ELB1200 can be clearly seen frame right. It's a little more difficult to see the ELB400 frame left, but if you look at the top of the bike on the platform, you can see the reflector the other side of the handlebars.
    Olympus E-M1 mkII 1/40th sec 12-40mm F2.8 @ F3.2 ISO400
    My portfolio site is here, my food site is here, whereas my wedding work is here.
    Olympus Mentor and Elinchrom Ambassador and I also run lighting courses.
    Re: Motorcycle Photography
    Clear and concise with excellent shots to back it up. Thanks.
