Third party battery failure for OM-D EM5 II
  • Third party battery failure for OM-D EM5 II
    Re: Third party battery failure for OM-D EM5 II
    I looked this up recently as I have a couple of spares from my old camera that I don't need. As I recall, new batteries in their original packaging can be posted, so it's ok buying new ones.
    Unfortunately used loose batteries can't be posted. The only legal way of posting used ones is with the electronic device they power, when you then can send 1 battery loaded and 2 spares.
    That's as I remember anyway - best to check yourself though... Memory like a sieve!
    Junk on Flickr
    Even more Junk on Instagram
      Can't return used batteries ..... Makes a mockery of guarantees when bought other than a b&m shop, doesn't it.
        From where did you buy the battery, was that Jessops as well as the camera?
        I believe your warranty lies with the vendor, rather than manufacturer/wholesaler.
        It's up to them how they deal with getting the battery back to Hahnel if they want it returned.
        Best Regards
        They're Watching You!
          Chris, Keith, Bill,
          Many thanks for replying so quickly and for your advice. It sounds as if Hahnel have covered themselves thanks to the refusal of the parcel services to carry batteries outside of their intended devices.
          I'll approach Jessops and see how helpful they're feeling; yes, Bill, I bought the spare battery from Jessops when I bought the camera, so they are the vendors.
          Now if used batteries can only be sent inside the device they're designed for, I guess that means that all third party batteries bought from online-only retailers are a one-way transaction; you can never return them if they develop a fault.
          Or else you need to send your camera body back with the battery inside - not an ideal solution.
          Cheers all,
          Russell
            Thinking about it, and in all fairness, if a battery needs to be returned to a postal vendor ....... the Post Office hasn't a clue what's in a parcel so just send it and see what happens. If they refuse to deliver it, nothing lost, you wouldn't get it changed anyway,. If it does get there then it's worth it.
            Am I wrong in thinking that
              Yes you are wrong, they have scanners and will destroy a parcel containing illicit items.
              I know of two people that this has happened to when sending loose secondhand batteries.
              Also why ignore the rules that could potentially put lives at risk
              Mail is often carried by plane and these batteries especially faulty ones can explode.
                So how do they tell the difference with their scanner, between a package containing a legitimate new battery, and a package containing an illegitimate secondhand one?
                  Now I accept that this is a slightly false scenario, as one wouldn't normally clout a battery with a roofing hammer, but they have been known to do this spontaneously as well.
                  This was a discharged faulty battery out of a mobile phone. As you can see it had expanded, much like the ones being discussed, though a camera Lithium Ion battery is enclosed and restrained by its rigid plastic case.
                  https://www.youtube.com/watch?v=q_YG...ature=youtu.be
                  How does one get the above link to display within the post in its own youtube panel, as seen in other posts?
                  Best Regards
                    No idea, maybe it was batteries not in the correct packaging and no warning label affixed.
                    Does it matter, why ignore the rules just because you don't like them
                      The outside of the packaging indicates that there are battereries inside.
                        My first advice would be, don't buy third party batteries & if you do, then you must have got it several times cheaper than the Olympus battery, so ....... move on & buy the recommended Olympus battery & then it isn't likely to swell as it uses correct protection circuitry when charging, something that may not be the case in that battery & was likely overcharged.
                          Apart from all the aspects raised on this thread there is one definitive answer.
                          You bought the battery from Jessops and it's their responsibility to deal with it.
                          Not sure why you ever contacted the manufacturer, seems an unusual thing to do.
                            I've bought several new batteries and they've never had warnings on the external packaging.
                              The batteries I got for my EM1ii came in properly marked packages. The rules seem quite clear that if a battery is defective you cannot post it. No matter what it is, if something goes wrong it is up to the vendor not the importer or manufacturer to sort the problem.
                              EM1ii, EM10ii
