If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Have attempted to rid myself of the W10 nag,nag, nag screen without success. Web search implies to remove a certain update but this has proved a waste of time as the sodding thing keeps coming back.
Does anyone know how to remove this pain in the neck once and for all?
It worked for me, but I have since uninstalled Silverlight & tried to hide that but it keeps coming back as an optional update, so I just have to avoid ticking that update when I'm taking any others. Thankfully the Get Windows 10 thing (update) doesn't re-appear.
Flickr: https://www.flickr.com/photos/ross-the-fiddler/ Cameras: OM-D E-M1 & Mk II, Olympus Stylus 1, OM-D E-M5.
Has anyone who has hidden the Win10 stuff found that windows update appears to be updating to Win10 but only installs updates to Win7?
I deliberately stopped my Alienware laptop from updating to Windows 10 after hardware damage to other AW17 owners which seemed to be connected to a problem in the GPU driver, uninstalled the 'nag' updates, blocked OS update using a registry key and took manual charge of updates, still get that infernal Windows 10 message!
I went to manual update (in Win 7), uninstalled & hid that "Get Win 10" annoying update ( http://e-group.uk.net/forum/showthread.php?t=39043 ) but I noticed it came back in the list again when I checked yesterday.
There is a way to disable updates with a registry key, but follow the instructions carefully as the registry is a dangerous place for the unwary.....
Serious problems might occur if you modify the registry incorrectly.
Before you modify it, back up the registry for restoration in case problems occur.
To suppress Windows 10 upgrade through the registry, specify the following registry value:
Subkey: HKLM\SOFTWARE\Policies\Microsoft\Windows\WindowsUp date DWORD value: DisableOSUpgrade = 1
One reason the 'Get Windows 10' can come back is if it is a new file; you'll probably find the Knowledge Base (KB) numbers are different...
Thanks. I'll leave the registry alone but had to modify it for the disappearing desktop icons issue.
The 'Get Windows 10' is the same number but a little larger file size this time (must have added a little more annoyance in it ).
Update for Windows 7 for x64-based Systems (KB3035583) Download size: 687 KB - 786 KB
Update for Windows 7 for x64-based Systems (KB3035583) Download size: 664 KB - 763 KB
I also uninstalled Silverlight & wondered why it kept coming back up in the listed updates but it does have different numbers for each occasion.
It's also worth checking to see if Windows has downloaded the update files 'on the sly' by going into 'Tools' then 'Folder Options' from Windows Explorer (not Internet Explorer which also has a 'Tools' header!) and on the View tab use the bullet point to 'Show hidden files, folders and drives' and also untick the 'Hide protected operating systems files' (Temporarily), and see if in your root drive (usually 'c') for a folder named $WINDOWS.~BT. This is the location for the Win10 update (or downgrade if you see it as I do!) and weighs in around 3gb; prior to using the registry hack it kept reappearing, but since using it the pesky folder hasn't had the temerity to return.
Here's a useful link with a comprehensive yet simple guide to clipping Win10's wings here:
Incidentally, if you find that folder in the root and have disabled the OS from updating it is safe to just delete it and reclaim some drive space; then reverse the Tools thing to hide hidden files and protect the OS files too.
Seriously Dave, it sounds daunting, but if you look at the link it is pretty straightforward AND if you scroll down about halfway there's a link to a simple file to do the registry hack for you; the site is one I have used a few times to fill in knowledge gaps and I consider it to be entirely trustworthy - I have had a look in the .reg file and it is 100% clean and will not do anything other than install the DWORD value needed to prevent Win10 from invading your system.
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
