lenses
  • lenses
    I have a an Olympus omd-5, plus a few others.............but also a Canon 7D I know wash my mouth out.with a 10-400 L lens..........I use it for birds in flight......which it is brilliant at doing........question is looking at a canon classic 70-200 F2.8 IS ...........but wondering is there a Olympus that is as good as I really do love my olys.
    Roberta
    E620, E30, OM4-Ti OM-D1... Canon 7D and 5Dmiii
    lenses 14-42mm, 40-150mm, 50mm, 18-180mm, 70-300mm, ec-14 still looking for a Bigma (Canon 17-55mm, 70-300mm and 100-400L)
    FL 50R and Hahnel remote (Canon and Olympus)
    Re: lenses
    I recently bought the 50-200 SWD f2.8-3.5 4/3's lens to use with the MMF-3 adapter on the E-M1 because it has PD-AF but the SWD lens would not work so well on the E-M5 CD-AF only, however the M40-150 f2.8 Pro lens also is available with the MC14 1.4 X teleconverter & many are singing its praises quite highly. That would be a good option for you on the E-M5. If you don't have a grip for it then that can be had cheaply here for $149 (half price).
      Re: lenses
      Hi Roberta,
      Well personally I would say .... "without doubt, the 40-150 F2.8 Pro" ,
      It is so sharp that the results can often 'knock your socks off' !
      The only 'fly in the ointment' I can see is that The OMD's are not as reliable at BIF as your Canon most likely is.
      Kind regards, Simon
      “Sharpness is a bourgeois concept”
      ― Henri Cartier-Bresson
        Re: lenses
        I'm still using my Canons for wildlife along with my Tamron 150-600.
        My 100-400L has been put in storage as I don't use it these days.
        I tried the Oly 75-300 but wasn't very impressed with the IQ compared to my Canons.
        I bought the 40-150 (cheap version) and have to admit to being rather impressed.
        The PRO version is even better but bigger and heavier which kinda defeats the purpose for me as I wanted something smaller and lighter to lug around.
        Mind you, its still smaller and lighter than my usual setup
        Until the rumoured Oly 300 f4 becomes reality, my Canons will still be my first choice.
        For everything else its my E-M1 these days
        https://www.flickr.com/photos/eos-mike/
        www.mstphoto.zenfolio.com
