EPL2 vs E620
  • EPL2 vs E620
    I have recently acquired an EPL2 with 14-42mm and have been playing about with it. I have been massively impressed by the image quality and find that the jpeg IQ is much better than my E620 - sharper and much better noise control.
    I am interested to know if others have found the same significant improvement?
    I assume this is down to the weaker AA filter and updated image processing - in which case I can feel an E5 looming!
    The attached is of sunrise yesterday taken with the Pen at ISO 1000, straight ooc. I know it doesn't show detail, but it was the noise control that impressed me.
    Martin
    Re: EPL2 vs E620
    If you like the Jpeg output from the E-PL2 you will like the E-5.
    It's a fantastic little camera, I just want get some better glass for it, I know I could strap on my 4/3rds glass but I'm really warming to these new fast minimalist Oly primes (12 and 45mm), I already have the lovely Panny 20 which works very well with it.
    Oh and the VF-2 is a must IMHO.
    Regards Huw
    Olympus equipment
    Capture One Pro
    My flickr
      Re: EPL2 vs E620
      I find the high-ISO noise control in Jpegs is much improved even in the first e-P1, however when taken as a whole the image quality in terms of 'niceness' is almost identical.
      I don't see much Jpeg sharpness difference if settings are carefully controlled : in tests which showed marked differences between Olympus bodies using the 12mp sensor the sharpness differences all ended up being simple mistakes in settings.
      Only the e-pL1 had a smidgen more real sharpness able to be squeezed out from RAW files.
      ( Not exhaustive tests, just concerning e-600, e-620, E-30, e-P1, e-pL1.)
