Olympus Pen E-PL1 showing blank screen with pentax k lens
  • HELP! Olympus Pen E-PL1 showing blank screen with pentax k lens
    Hi,
    I have an Olympus pen e-pl1 camera, and bought a pentax pk to m43 lens adapter with some pentax pk lens. When everything is connected, the camera shows a black screen, but you can get into the different modes. Is there any settings to choose from on the menu or any changes needed to be made, to get the pentax lens working or even anything showing on screen? When I put the standard M Zuiko kit lens back on, it works as normal.
    Hope someone can help out
    Thanks
    Re: Olympus Pen E-PL1 showing blank screen with pentax k lens
    Originally posted by RPXL UK View Post
    Hi,
    Thanks
    Is the lens fully stopped down when it is mounted on the camera? It may simply be too dark to show anything?
      Hi,
      The adapter is properly attached to the body and lens is aswel. I tried it in light conditions, same problem. By the way I am an amature photographer.
        And I have rotated the aperture ring, opened and closed. Same problem
          If you put the normal lens on is everything fine?
          Which exposure mode are you using when the Pentax lens is fitted?
          Update - sorry - just read in the first post that the normal lens works OK.
            Hi
            Yes, when the normal kit lens is on, everything works. When using the pentax k lens, I try all modes, such as A, P, M. But dark screen, you can see info though such as ISO, M, etc
              Wonder why it is not working
                I have an OM lens mounted onto an E-PL1 using an MF-2 adapter here at the office and I haven't encountered a problem like yours. So this is a mystery!
                  Is there an option on the e-pl1 to switch off lens? I think on the panasonic m43 cameras there is an option to shoot without lens or something? That is what some people say on other forums regarding this.
                    I get this if the lens release button is not fully engaged and locked the lens onto the body. Press it in, turn the lens as if to take it off, then turn it back and listen for the click as the lens release pops out.
                    Hope this works.
                      There is an option for setting the focal length for accurate image stabilisation but I'm not aware of a setting for manual lenses other than this on Olympus cameras.
                        Stupid question, but to rule out the obvious, is the lens cap on the Pentax lens? I've left the cap on mine a couple of times.
                        BTW I use a Pentax lens on the E-M5 which works fine.
                          Originally posted by Graham_of_Rainham View Post
                          I get this if the lens release button is not fully engaged and locked the lens onto the body. Press it in, turn the lens as if to taks it off, then turn it back and listen for the click as the lens release pops out.
                          Hope this works.
                          That could be it I concur here with the E-PL1 in front of me. In fact there is a microswitch on the lens release button (on the camera body) and even if that is only pressed the screen goes blank. It could be that the Pentax adapter is not accurately machined and the lens release button is not being allowed to lock properly?
                            I think you guys have got it! Though its not going to work for me. When i attach the olympus kit lens it makes a nice clicking noise, and the pentax m43 adapter doesn't. So this is it. Anyway to fix the problem????
                              The problem is with the Pentax adapter you are using. If you look at the camera's lens mount without the lens attached you will see a small lug at 3 o'clock sticking out a millimetre or so. When a lens is mounted but not in the correct position (fully turned in the mount) that lug is depressed and remains flush with the lens mount surface until the corresponding hole on the lens side of the mount aligns with the lug. The lug then springs back forward and the screen should work properly again. If your adapter doesn't have the corresponding hole or it has not been machined properly or is machined in the wrong positioned, you will have a problem as you have described. If the mount won't turn far enough, for example, you will need to get the adapter replaced.
