damage code help
  • damage code help
    Checking the shutter count on my E-P1, page four, 'D', has 8903 on it. I understand that this is an error/damage code but I've no idea what it is. The camera seems to be working fine so I take it that it's not terminal. Can anyone shed some light on what it means?
    Regards - Paul
    Regards - Paul
    Re: damage code help
    Sorry Paul, I've no idea, but how do you check the shutter count on a Pen?
    I've been trying to find out since I got it.
    Best Regards
    They're Watching You!
      The E5 is done the same way as the PEN's. Hope this is successful.
      E5 Maintenance Menu
      Here are the steps:
      ► Camera OFF
      ► Hold down MENU button and turn ON the camera
      ► Release MENU button and press MENU again to get to Menus
      ► Go to LCD Brightness Menu, that's in Spanner Menu and third item down.
      ► Press RIGHT to show screen adjusters
      ► Press INFO and then press OK and on my E-5 this shows on screen....
      OLYMPUS E-5 0A 01 01 01
      ► Press in sequence UP/ DOWN/ LEFT/ RIGHT/ SHUTTER/ UP and Page 1 info appears
      ► Variously press RIGHT for Page 2, DOWN for Page 3, LEFT for Page 4 and UP again to get Page 1
      What we are looking for is the information on Page 2, on my E-PL1 it shows.....
      R 000275 [total shutter actuation count]
      S 000020 [shot count with flash]
      C 000000
      U 000106 [turn on count which is ultrasonic wave cleaner count]
      V 000000
      B 000204 [seems to be total number of times shutter button is fully pressed for any reason]
      L 000000
      On Page 4 is D: damage code log, mine shows 0 and that is good.
        Sorry Bill, I've only just spotted your reply. Anyway, Ross beat me to it.
        Regards - Paul
        Regards - Paul
