Help please - OMD auto ISO
  • Help please - OMD auto ISO
    Is there a way I can set the minimum shutter speed when ISO is set to auto? I find auto ISO really useful, but I'm sometimes getting shutter speeds lower than I want. I'm using aperture priority mode.
    The Nikon system I'm used to doesn't vary the speed to allow for the focal length, but it does enable the user to choose a minimum shutter speed.
    And while I'm posting, what system do Raw shooters find best? I've been using Adobe ACR but it doesn't recognise EM5 Raw files.
    Rens
    Re: Help please - OMD auto ISO
    Rens
    I use LR4, which uses ACR. The latest versions of ACR recognise E-M5 files, so perhaps you need to upgrade?
      Hi Rens when using auto iso and control shutter speed to a set shutter speed select shutter priority, if you need control of both shutter speed and app then use manual and dial in tour shutter speed required and f stop with front and rear dials. then you are set to go.
        You can set a minimum shutter speed, which enables you to still shoot in aperture priority but ensuring the shutter speed does not drop below a certain level, set by you. This is done, oddly enough, by setting the slow sync speed for flash in the menu. This also sets the minimum shutter speed when using Auto ISO without flash.
        Menu > Gears > F (Flash Custom) > Slow Limit > use up/down arrow keys to adjust.
        Depending on what software you are using you may be able to download a later version of ACR which does accomodate E-M5 ORFs.
        For example, I had Elements 9 but this did not support the latest ACR so I upgraded to Elements 10. This did not come with the right version ACR but it does support it and I was able to download it free from the Adobe support site.
        Elements 10 users are now experiencing the same problem with the new E-PL5 and will have to upgrade to Elements 11, or choose an alternative such as Lightroom.
          Thanks, I wouldn't have found this.
          Rens
            I use Capture One Pro version 7
            Even version 6 supported the E-M5 from very early on.
