Don't update to E-M5 1.2 firmware for now.
  • Don't update to E-M5 1.2 firmware for now.
    Because of some reports of problems after updating to v.1.2 firmware for the Olympus OM-D E-M5, Olympus is advising that if you haven't yet updated, hang on until further notice.
    Re: Don't update to E-M5 1.2 firmware for now.
    I have already but I won't PANIC YET
      I have seen one post where someone says their camera stopped working after the update, so it may be related to that. But if your camera was OK, then hopefully you are safe.
        any idea what the problems may be - I've just updated mine and they tell me there us no way back!
        (It all went very smoothly despite being my first "Olympic Upgrade")
        just seen your last post Ian, thanks
          Thanks Ian. I thought I would wait till after this weekend & be able to take it into Oly service if I needed to you (if it might have been unsuccessful). I shall wait & see what happens from here.
            I completed the update but now worry lots as to problems that I dont yet know about . Highly poor show if they dont email their registered buyers of the camera..why cant they email us to say when updates are available or when there is a problem?
              Four people over on mu43 with bricked OM-D's now due to the update....
                Really...? b***er!
                I updated mine yesterday without any problems and it seems to be fine.
                What happens if your pride and joy ends up 'bricked'?
                Edit: Having quickly read through the thread on mu43 it appears the problems occurred because the update failed while in process.
                Regards Huw
                Olympus equipment
                Capture One Pro
                My flickr
                  Originally posted by Greytop View Post
                  Really...? b***er!
                  Yea I really hate Olympus for there way of updating just for that reason and always do it with some trepidation.
                  What wrong with downloading the update then copying it to a SD card and doing it from there as other Brands do?
                  Regards Paul.
                    A very good point Paul, it would make a whole lot of sense to take away a large percentage of the risk.
                    Regards Huw
                    Olympus equipment
                    Capture One Pro
                    My flickr
                      Really...? b***er!
                      That's what I thought was the issue. It is a risk if everything is not done correctly with reliable connection & power, but once it is in I don't think there is a problem. It isn't an update I need (as far as I know), so I'll wait for the 'all clear' from Oly before I do, although I'm only one hours drive away from Oly Service here should I need it.
                        I am absolutely sure that Olympus would ensure that affected people were helped accordingly.
                        It doesn't look like anyone here has had a problem so that's positive.
                          Olympus has operated the same firmware update system for 9 years and it has worked fine in that time. There is obviously a limited issue with the current update which a small number of people are experiencing.
                          Not everyone has registered their cameras and even those that have over the years may have changed their email addresses or are no longer owners of the registered cameras so emailing is not a reliable communication tool in this respect.
                          The best thing is to keep an eye out for news on sites like ours here.
                            There's a big difference between a download update that fails in progress and an update that suceeds but contains a camera bricking bug. ()
                            If it is the former, then I can imagine you might get problems with all the new E-M5 owners trying to download from the server at the same time. This might make something in the (long drawn out and potentially flaky) process go wrong. I've updated all my Olys using this method for a few years and not had a problem, but it takes so long and seems inactive a lot of the time, so you could easily think it has failed and unplug something.
                            Is it the latter? No, I hope not and until I hear otherwise I am going to declare it a storm in a teacup
                            Mmm. speaking of which: Time for a nice cup of tea.
                              Did the upgrade yesterday and all seems fine. Slow process but hopefully not one that will be needed terribly often.
                              thephotographersblock.wordpress.com
