EM5 mark2 S.AF / MF
  • EM5 mark2 S.AF / MF
    Hi
    I have an urgent query!
    I am currently borrowing an EM5 mark2. The camera is flipping on it's own between S.AF and MF! Then gets locked in MF and the viefinder is blank!
    This happens no matter which lens I put on it.
    Advice urgently needed as I need this for a job this Saturday.
    Thanks!
    Sisi
    Sisi Burn
    Photography for musicians.
    www.sisiburn.com
    Re: EM5 mark2 S.AF / MF
    Not a problem I've encountered with mine. Sounds like it might be a Portugal job. I assume if you're using a 12-40 or 40-150 that you're not inadvertently switching from manual to AF on the lens.
    EM1ii, EM10ii
      Thanks for your reply.
      I may have solved it by doing a camera re-set. I hope. Fingers crossed!
      Thanks.
      Sisi Burn
      www.sisiburn.com
        I see you must have got around your problem with your inclusion in the Olympus Magazine. Congratulations!
        See here. http://e-group.uk.net/forum/showthre...323#post362323
