Testing Airplane mode for birds
  • Testing Airplane mode for birds
    Typical new camera weather! It's been great for days and now it's dull and raining. I was keen to try out the new Airplane tracking mode on the EM1X and see how it well it worked for birds. I was also able to check out the weather proofing!
    Despite the weather the camera did recognise larger flying birds such as crows, buzzards and red kites and put a white box around them to show they were detected and then tracked them most of the time. It will take some time to get used to it and make the most of it, but the initial tests look promising. It’s lucky that the Artificial Intelligence is not so intelligent that it can’t be fooled by a bird.
    This photo was very under exposed - probably needed nearer +3 stops of exposure compensation rather than my standard +1 for BIF. So not the best image after I have tried to rescue the shadows, but it looks to be in focus.
    Red Kite in the rain
    Looking forward to trying it in better light, but the forecast is not looking good just now.
    bengeo.com
    Re: Testing Airplane mode for birds
    Nice! Is there an option for 'spot exposure' corresponding with focus points?
      Looks sharp to me and nice to know AI is an option for birds .
      Rob.
        Not in this case, it only works with single target or small target.
        Normally I don't go out in weather like that to photograph birds and usually I would be more prepared. From experience, when you start adding +2 or more exposure compensation then it's usually not worth bothering with the shot.
        bengeo.com
          Just trawling through my photos, I've just noticed one of my film film cameras has 'aeroplane' mode!
          Jet by -Steve Ricoh-
          Nothing new under the sun, as they say!
