not converting Raw files in viwer 1 and 2
  • not converting Raw files in viwer 1 and 2
    went to process some images from to-day but the viewers would not batch or single convert.
    When I was shooting it did not want to focus ..I was using Aperture, as normal..
    . , I downloaded as per normal..with cable to computer... tried to use the file on system I stored from yesterday.. it said could not do as images with same number... they were taken using a E30...
    I have reformatted the camera
    Any ideas...
    Roberta
    E620, E30, OM4-Ti OM-D1... Canon 7D and 5Dmiii
    lenses 14-42mm, 40-150mm, 50mm, 18-180mm, 70-300mm, ec-14 still looking for a Bigma (Canon 17-55mm, 70-300mm and 100-400L)
    FL 50R and Hahnel remote (Canon and Olympus)
    Re: not converting Raw files in viwer 1 and 2
    Try doing a “reset” of the camera. Hold down the +/- and ISO for at least 10 seconds (it may be only 5)
    If that doesn’t work, take the battery out and leave it for as long as you can, so the camera resets itself.
    I had something similar happen once on my E-3
    Good luck
