Which glue?
  • Which glue?
    My EM-1 is following the E-1 in the rubber peeling from the thumbrest area...so which glue works best
    If the weaher sealing compromised?
    ta
    chris
    shetland
    Re: Which glue?
    Any "Contact Adhesive" NOT super glue
    http://www.wickes.co.uk/Wickes-High-...e-30g/p/241100
      Re: Which glue?
      Is it not still under warranty?
      All the best
      Lots of cameras and lenses.
        Re: Which glue?
        Yes but that means I wouldn't have It for any jobs that came up
        If it didnt work, there would be little loss
        So time to dig out the Evo stik
        chris
        shetland
          Re: Which glue?
          Either a contact adhesive or heavy duty double sided tape.
          David M's Photoblog
            Re: Which glue?
            I used evostik on my OM1 when this happened in around 1979!
              Re: Which glue?
              Camera repairers have a preferred contact adhesive, I've got a can somewhere but can't remember the name of it. Heavy duty double sided tape works well if recovering a camera with different material. Some of my OM bodies are recovered in a silicon anti-slip material.
              David M's Photoblog
                Re: Which glue?
                Use DIY sticky-stuff and the Warranty won't stick.
                  Re: Which glue?
                  I had same problem, after one trip out in rain it came off completely so had it fixed under warranty and they also cleaned it. A 7 day turn around.
                  Gary
                    Re: Which glue?
                    A quick Google shows it's Pliobond.
                    David M's Photoblog
                      Re: Which glue?
                      Mine is peeling off too now.
                        Re: Which glue?
                        I used Evo . stik ... It is still attached
                        chris
                        shetland
                          Re: Which glue?
                          Try copydex apply to both sides let it dry then bring them together, should work.
                          Ed
                          What if the Hokey Cokey is what its all about?
                            Re: Which glue?
                            Evostik = contact adhesive, perfect stuff for this and doesn't damage stuff.
                            I get mine from ToolStation which currently has the best price for big tubs ... which is irrelevant in this case.
                            Go to the nearest 50p-shop.
                              Re: Which glue?
                              Copydex, as 'Wee Man' suggested is a good idea for an initial try. It's a latex emulsion and shouldn't have any effect on the substrate. If it doesn't last, you can rub the old adhesive off with your thumb, leaving the surface clean and undamaged for another try. Cow Gum may also be worth a try, as again it's a rubber base dissolved in a petroleum spirit.
