S-AF+MF not available
  • S-AF+MF not available
    Hi,
    When using my Zuiko 300/2.8 lens with the EM-1 Mark 2, fine adjusting of focus manually is not possible since the S-AF+MF AF mode is not available for selection. When using the EM-1 Mark 1, that mode is available and I can fine tune the AF manually.
    Any idea what could be the cause?
    Thank you.
    My Gallery on 500px
    Re: S-AF+MF not available
    A number of features were changed in the new firmware 3.1.
    It is all in the revised manual.
    S-AF+MF is available.
    Youi have to decide if you are someone who likes the +MF feature or not. Once you tell it, it will appear.
    Go to menu A1, second line down, and turn it on.
      Many thanks for this, I was not aware of this new feature.
      Best wishes,
      Tord
      My Gallery on 500px
        Also with MF (& +MF), note the shortcut method of changing Focus Peaking settings with the Info key too (colour & intensity plus ON or OFF). https://e-group.uk.net/forum/showthread.php?t=51278
          I love 3.1. Several individually small but real-world useful tweaks that I use every day.
