Firmware 3.1 out
  • Firmware 3.1 out
    Fixing some of the bugs reported on 3.0.
    Re: Firmware 3.1 out
    v3.1 Update does the following:
    - Stability of operation when shooting still images has been improved.
    - Stability of EVF operation when the camera is turned on has been improved.
      Update done all seems fine.
      Thanks for the heads up.
        Gosh that was a pretty quick revision to 3.1.
          Thanks. All done (quickly took SD cards out, put in full battery & removed lens, just to minimise any issues).
          There is one thing though, you will need to reassign the SD card recording order again (Mine is slot 1 photos, slot 2 video & Auto switching from one card to the next when full).
            It's kept the shutter speed and slot assignations in the C menus though - which it didn't last time!
              Thankfully they did. One source had issues with video/sound not syncing correctly for external HDMI recording & now it's fixed.
                We wait ages for one, then get two in just a couple of weeks.
                Blink and you'll miss them!
                  It is de rigeur nowadays for ver.X to be followed very quickly by ver.X.1. Customers are used as bug-testers.
                    Loaded v3.1 no problem.Went out in afternoon to local quarry was taking shots in S-AF mode when a sparrow hawk flew low across me about 20 yards away, was on low shutter speed and low ISO with single small square focus point, managed to lock on panning for 2 reasonable shots, seems like there is an improvement in S-AF or maybe just luck.Promptly deleted photos accidently on editing in camera, have repeated this mistake several times, keep forgetting to lock photos first.
                      Originally posted by bigsambwfc View Post
                      ...........Promptly deleted photos accidently on editing in camera, have repeated this mistake several times, keep forgetting to lock photos first.
                      You should get some SD-card recovery software - it's saved me a few times. Providing you haven't over-written the files, you should be able to recover the images because it's only the index that is re-written, when you erase or 'quick' format.
                        Sorry you lost your shots. Years ago I was told/taught not to delete or edit in camera, as it can cause problems later on with the SD card. Is that not true anymore?
                          Great news - I've been plagued by the EVF bug in 3.0 today. Turn the camera on and the image in the EVF is black with just status info like you have a lens cap on! It happened with the EVF set to high frame rate and EVF default style 3.
                            Instagram: TheBassmanBlog
                            My Blog: TheBassmanBlog.com
                            My Pictures: abbeyworks.smugmug.com
                              Same. I might scroll through them, but save deleting for once I have a safe copy somewhere.
