F1 as AF Home not working after upgrade to 3
  • F1 as AF Home not working after upgrade to 3
    I upgraded to firmware 3.0 this morning.
    I have always used the default setting for the F1 button - it changes the AF target to it's home position. That has stopped working. I have checked all the relevent settings and they are all as should be.
    The F1 button works for several other selected functions, so it's not the button at fault.
    The F2 button doesn't work as "Home" either.
    Anyone else found this? Any solutions? Or is it a software error in the new firmware?
    Jeremy Cooper
    Please see
    http://www.oliophoto.co.uk
    http://www.oliomedia.co.uk
    https://www.blipfoto.com/oliophoto
    Thanks for looking!
    Re: F1 as AF Home not working after upgrade to 3
    Home button works fine on firmware 3 (FN1 or another button you assigned), I suggest a reset to your camera.
      You have to set the F1 button to Home, as you have done.
      But you also need to tell it where and what Home is:
      Cog menu, A2, Set Home.
        Thanks Growltiger, but I have done all that.
        Jeremy Cooper
        Please see
        Thanks for looking!
          Thanks kbouk. I'll try that.
          Jeremy Cooper
          Please see
          Thanks for looking!
            Did you allow the settings to be reloaded after the update?
              Yes I did Ross. BUT ...
              I have just saved settings, reset camera, reloaded settings, and all is well. I'm a bit surprised as I expected the reload to reload the problem: but it didn't.
              Thanks for replying.
              Jeremy Cooper
              Please see
              Thanks for looking!
                It worked kbouk, even after I reloaded the saved settings. Thanks.
                Jeremy Cooper
                Please see
                Thanks for looking!
                  I found this as well. I had to 'remind' the camera what the actual home setting was (ie centre single point for me) and then it worked fine again.
                  https://www.flickr.com/photos/99443690@N04/
                  www.tobygunneephotography.com
