Assign button to Mono, another to 1:1 format.
  • Assign button to Mono, another to 1:1 format.
    I don't think it's possible, is it?
    I'd have to use either C1,2 or 3 I'm thinking.
    Re: Assign button to Mono, another to 1:1 format.
    Anyone ..!
      You can use multifunction button assign to aspect ratio for 1:1.
        Thanks, not quite like assinging it to a button though.
        I don't want to waste a custom mode on them, be nice just to press a button.
        I feel sure it cant be done, just wondered if anyone had a 'work-around'.
          Multifunction button is Olympus name for a button function, not a custom mode. By default on every Olympus camera is assigned to FΝ1 or FN2 but you can change that and assign the function to another programmable button. It can be used for 4-6 different options as: magnify, aspect ratio, H/S curves ...
            Thank you.
            The simplest way I've found yet is via the SCP.
