EM-1 MkII freezing when using live bulb and live timer
  • EM-1 MkII freezing when using live bulb and live timer
    Has anyone else experienced this since the new firmware update?.
    The image builds on the screen fine but when the shutter closes either by releasing the button or pressing it again dependent on mode, the screen goes black with the histogram showing bottom left and the display count and exposure time bottom right. The only way I can get the camera to rspond to any button or the off switch is to remove the battery. No image is saved.
    This could be a new glitch.
    Re: EM-1 MkII freezing when using live bulb and live timer
    Have you got "noise reduction switched On"? If yes try with set to Off
    My camera seems to work fine
    Hope this helps
      Hope this helps
      Thanks for the reply. My noise reduction is switched off. It was the first thing I checked when the issue arose.
        Works perfectly here. Try removing and replacing lens. Try another lens.
          This forum is populated with very knowlegeable folk. Thanks for this I had not considered dirty contacts. A quick clean and all is well.
            I'm glad to hear that solved it.
              I've lost count of the times over the years the great people here have solved a problem or taught me something useful!
