High Res shot and studio flash - not working on EM1 Mk2
  • #61
    Re: High Res shot and studio flash - not working on EM1 Mk2
    All is fixed in the latest firmware update today.
    https://www.olympus.com.au/Learn-Exp...mware-Upgrades
    • #62
      Hi Ross, Good to see you here
      My portfolio site is here, my food site is here, whereas my wedding work is here.
      Olympus Mentor and Elinchrom Ambassador and I also run lighting courses.
      • #63
        Thanks. I haven't been doing much with my camera this year & have spent more than I could have on the E-M1Mk II on battery powered tools for the garden & workshop etc instead & so I've been a little quiet here as a result (& on other forums). I've been watching price reductions happening for the E-M1Mk II & maybe by Christmas that might be a possibility. I'll have to sell more violins though.
        I should add, it's nice to see you here on this great forum too.
        • #64
          Just checking, was this problem corrected in such way that you can use non-olympus flash transmitters in HR-mode? Obviously profoto and elinchrome should work, but I am interested in younguy and other cheap center-pin transmitters.
          I am in planning to do some repro-photography of some museum stuff and plan to use EM-M1 mk II in HR-mode. I also have 3 FL-50R (and FS-SRF11 & FS-STF22, but range is too limited) but I am sceptical whether those will get optical rc-command from flash in camera as the FL-50R's are located inside softboxes. So I think that I should obtain some cheap rf flash transmitters. I have already ordered softboxes, but as time is of essence I might need to order flash transmitters before getting softboxes.
          One of challenges is the large size of artwork which is being reproed, they are approx 2-3m wide so with 50mm F2 (old 4/3) I have to get quite far from art.
          Any guidance is welcomed,
          Tuomas
          • #65
            Tuomas
            The issue with the central pin was resolved in the next firmware date, about three months later.
            If you can get a hold of a 25mm lens, it would likely better suit your needs.
            • #66
              Originally posted by super_claret View Post
              High Res Shot has a setting of its own. Camera Menu 2 > High Res Shot. When selected it displays an offset grid indicating sensor shift (I presume). I cannot change the shutter/drive modes.
              There is no option to enable flash in high speed silent.
              I don't think it's possible to use flash in Hi Res mode. The sensor camera takes a series of shots with the sensor in different positions and is combined into a single image. If Flash is to work, it will have to have to flash with each of the shots.
              • #67
                I know there was a delay time for flash charging in Focus Stacking & so thought there is no reason for it not being possible in High Res too, so I went looking & in Shooting Menu 2 there is the settings for High Res Shot which does allow for flash charge time (up to 30 secs) & also post shutter delay.
                • #68
                  Imagine what artistic images we can do with that The HiRes is suppose to combine 5 sensor shift to create this, right?
                  • #69
                    No issue now, although there was initially, which was sorted with a firmware update.
                    https://www.sewellshouse.co.uk/blog/...-studio-flash/
                    • #70
                      It's actually 8 positions, so seven delays for the flash to charge & flash.
                      • #71
                        Will definitely have a go with this knowledge. 8 exposures
                        Thanks
                        • #72
                          Great many thanks for your comments.
                          Actually I have tried HR-mode with flash (2x Fl-50R) and it works nicely. Needed some fiddling around timings in menus, but worked. Problem was that Oly RC-stuff uses onboard flash to control FL-50R's so I suspect that it wont work with flash enclosed in softbox.
                          I have also 35mm F3.5 macro, which could be useful. I am just trying to get best possible results from this as the museum stuff is challenging to organize. Even getting originals out of their storage is challenge and setting everything up. I guess that this will be one-off-effort which will not be repeated.
                          Is there some kind of receiver for Godox flash transmitters (X1T-O TTL, Xpro-O TTL) which could be used with FL-50R? And does somebody know that they work with HR-mode?
                          Tuomas
                          • #73
                            I think that I have solved this problem. I ran into this product
                            See godox site for S_type_Speedlite_Bracket
                            Which allows using bowens-mount softboxes with FL-50R. Cannot get confirmation whether it fits, but it looks promising. Actually I ordered 2 combos of S-type bracket and foldable 60x60 softboxes (product is this, see ebay fo DE-Godox-60x60cm-Faltbar-Softbox-Bowens-Blitz-Schirmhalter-fur-Aufsteckblitz).
                            Idea is to allow end of FL-50R flash to stick outside of softbox. This then make it possible to use Olympus RC-control.
                            Hope this works & I will keep you posted.
                            Tuomas
                            ps : yes... I would have posted direct links but ... forum sw says that I must have postcount greater than 6. Which I do not have.
                            • #74
                              Greetings,
                              Idea I presented in previous message was excellent in writing, but in practice it did not work. Getting FL-50R's reliably working with softboxes in large room using oly RC-signalling proved to be challenge. I got roughly 1/2 of shots working and with Hires-mode you need to have 8 good shots in row. Sadly, fail.
                              I then bite the bullet and purchased 2x cheapo Godox SK300 II's with matching X-pro-o-controller. This works like a charm. Even with Hires-mode.
                              Tuomas
                              ps : I am just a bit slightly disappointed as I have been oly user since E-300 (and before that from C-400, E-100, E-10, E-20, E-3, E-5, E-400, E-500..) and owning almost every possible gear Oly has sold. This is first non-oly gear in decade. But it works and that is only thing in real life which has meaning.
