Hyperfocal Distance
  • #16
    Re: Hyperfocal Distance
    Originally posted by snaarman View Post
    Checking with exposureplot I find I am a f8 maniac. The vast majority of my snaps are done at f8 +- 1 stop.
    Creature of habit?
    Pete
    I just tried this for the first time and found that by far I'm
    Focal Length approx 30mm
    Iso 100
    Aperture f6
    Shutter speed 1/80
    Makes you think why we buy all this kit doesn't it?
    Jamie
    • #17
      By f/8 you are starting to lose resolution through diffraction softening. f/8 is like f/16 on full frame - do you need more depth of field than that? At a moderate wide angle of 18mm, at f/8, the hyperfocal distance is down to 9 feet. At 12mm it's down to 4 feet.
      Thanks Ian
      Sounds like I am not even the same ball park. I will start using lower fstop and
      see if things get better. I must admit that I have been happy so far with my images although some are a bit soft and I think you have answered that question for me.
      Thanks again
      • #18
        Interestingly the DOFMaster calculator on their site shows 7.91 ft as the hyperfocal distance for 12mm at F4. If you change the camera to an FF like the C****n 1D etc and enter 24mm and F8 you get 7.95ft which is marginally different. I presume, without doing the research and resorting to pythagaros that the diagonals of FF are not exactly 2x 4/3rds or the calculator is internally inconsistent. I have the DOFMaster app on my iphone which I have not yet used in anger so it is worth knowing that it may not be accurate.
        www.jim-mccabe.co.uk
        http://www.jimmccabephotography.blogspot.com
        (My Travels in Aus & NZ)
        • #19
          There are a lot of approximations in photography arithmetic, so I think this is within the margin of error - it's less than half an inch
          • #20
            Originally posted by David M View Post
            Not really, I suspect you're trying to get the best out of your lenses, even if you're doing it subconsciously.
            Checking Lightroom the vast majority of mine are f5.6 to f8.
            Yes, that's a very sensible range
