Tripod - should I get one?
  • Tripod - should I get one?
    Help me.
    A. Why did you get one?
    B. hat did you get? tripod/head
    C. What do you use it for? (if different from A.)
    Alan
    Re: Tripod - should I get one?
    B. What did you get? tripod/head
      Why do you think you need a tripod? What type of images do you take?
      I purchased my first tripod years ago......and until recently (1-2 years), I could count the number of times that I had used it on one hand. I have recently upgraded.
      For most of the time I find that my monopod get used the most. If you don't have one I suggest getting one before getting a tripod.
      Now regarding tripods, you can get cheap all in one units. They are not great, but cheap, and allow you to learn.
      I went for a seperate head and tripod.
      I use mine for any shots that needs to be steady, t high focal lengths or for long exposures.
        Alan,
        I bought both a tripod and a monopod as I have an E-410 and a 70-300mm lens. With the 70-300 on full lens extension I find it difficult to get a sharp image as the E-410 has no image stabilisation. However, I've got to say that I don't carry either about with me normally as they are too bulky. I've only ever used them for night shots I've planned beforehand or in my back garden for wildlife and macro use.
        Hope this helps
        Jamie
        Jamie
          Bob
          To see what is in front of one's nose requires constant struggle.
          GEORGE ORWELL
            Hmmmm! sounds and looks interesting Bob. Is it complicated to fit/wear? and would it possibly work with the 70-300 and EC14?
            Steve.
              I have a Manfrotto tripod and a monopod, I don't use the tripod much but I use the monopod all the time, helps with composition and using slower shutter speeds, I leave it fully extended with the camera and lens attached and carry it by the monopod grip where it balances nicely and is ready to use. The tripod and monopod are both 3 section (2 clips on each leg) as this makes them faster deploy even if they are a tad bigger than a 4 section type.
                Steve.
                Hi Steve.
                It's similar to using the camera strap taut against your neck to steady the camera. It has an adjustable column the bottom of which sits against your chest and you can raise or lower it to suit the camera position. You can also adjust the head angle as well as lock the column into position. The camera plate is removable and can be left on the camera. When closed it's about 10" long and it weighs a little over 7.5 ozs. I think it's useful for those occasions when you can't carry a tripod or monopod and it's not at all difficuly to fit or wear.
                Can't see why it wouldn't work with your lens. Let me know how you get on with it if you do get it.
                Best regards
                Bob
                Bob
                GEORGE ORWELL
                  Steve.
                  On second thoughts, Steve, you will still be using your hands to help steady the camera + lens, so perhaps a tripod would be best with that lens and EC14. See Meach's thread today on this subject.
                  Bob
                  Bob
                  GEORGE ORWELL
                    Originally posted by jalanb View Post
                    Help me.
                    B. what did you get? tripod/head
                    Alan
                    A: Every photographer should have a tripod. It impresses folks when you turn up with one. (Larger tripods impress folks more).
                    B: I bought a cheap Cobra with pan tilt and twist, centre column and leg bracing - its not that bad really. Some years later I bought a big Manfrotto with a similar sort of head (074 tripod and 141 head). The Manfrotto weighs a ton, it looks really impressive and is as solid as a rock. However - I only use it about once a year because its so heavy.
                    C: I use the cheap tripod to support flashguns and lighting and it gets used for pictures occasionally. I would only use the expensive one for super critical stuff (I did a dawn panorama with a 200mm lens last year - low light, long lens, sharp results needed)
                    So - my vote would be for a lightweight but good tripod that you might take with you, plus a heavy and excellent tripod that probably stays at home.
                    Pete
                    PS. A pearl of wisdom I heard. Never buy a tripod that is heavier than your wife/husband will carry.
                      I have a lightweight tripod that I use about twice a year. I bought it in order to take low light images of specimens in museums, and also use it occassionally for birds in the garden when I can hide in the shed!
                      I don't really take it many places and certainly don't carry it around on spec as even a light one just makes everything all too bulky.
                      Cindy
                      Cindy
                      Cameras: EM1 MK2 and Mk1, E-620, E-410, Om4Ti
                      Lenses: 12-60, 50-200, Panny 100-400, 9-18, ZD 50mm, 14-54 Mk1, 70-300, 40-150, 14-42, OM 50mm F3.5 macro
                      Also: EC14, EX25, FS35, Vanguard tripod, and far too many bags!
                      "The air of heaven is that which flows between a horse's ears...."
                        Bob
                          Cindy
                          Hi Cindy
                          What you need is a wife (!!). However, mine got fed up carrying my large camera bag and tripod all weighing half a ton and with me only holding the camera. Hence the 4/3rds system and just two lenses. However, I'm now building up again with my old Minolta lenses and adapters. I've already received a big NO from Julie.
                          Welcome to the group.
                          Bob
                          Bob
                          GEORGE ORWELL
                            Absolitely needed for low light shooting - even if not fully locked off it's like goving you another 4-5 stops in stability which allows lower ISO's and highe F Stops which greatly increases your range of pictures you can take In Camera IS can compensate, but thinks like 10 seconds light trails and things like that are not feasible unless you have a tripod
                            I have multiple.
                            The general rule for a main tripd is get the biggest / most stable you are willing to carry. It will pay off when you use long lenses etc.
                            These days Its with a seperate head, but I don't think that's terribly important as you can add a head to one that doesn't come with one later if you decide you need one.
                            All my big ones have quick release plates on the heads / or on the tripod if it didn;'t have a head. I think that's the main attribute I would say is important. Pick a system and then stick to it so you can buy spare plates and leave one on every camera.
                            Having said all that the device I use most often is a small Jessops own device which I can't find on their website so here's another link http://www.comparestoreprices.co.uk/...ble-tripod.asp
                            The reason I use it most is it's always in my bag and it turns anything such as fenceposts and railings into a tripod. it will hold an E-30 + kit lens, but only if everything is in balance. I would never rely entirely on it for an impotant shoot, but for everyday opportunities it's superb
                            My Kit (OK I'm a hoarder...)
                            My places
                            http://www.shenstone.me.uk
                            https://vimeo.com/shenstone
                              I think there comes a point in every photographer's persuit of their craft, when a tripod is considered. For many years, I used cheap ones that were never really that stable, which kind of undermines the reason for a tripod's existence! It is only in the last ten years that I have invested in a decent full size model with one of those Slik pistol grip heads, and a very robust table top model. I also have a monopod that I find useful from time to time.
                              I may go months before needing to use any of them, but there are always times when I need to call on one or the other, or projects where their use is unavoidable.
                              Buy the best you can afford and carry. Avoid models that have too much plastic in areas that take stress. Buying a good one will mean you will have it for many years and not have to revisit it due to some crummy part failing.
                              Regards, Steve.
                              visit my website www.photoark.co.uk
