Low Self Discharge AA Batteries Tested
Reviewed by Chris Dowling 20th August 2009
This is my first attempt at writing a review which I hope will be informative, and most importantly, will actually be of some practical use to you, the reader. I have had somewhat of a love/hate relationship with rechargeable batteries as I have found it very frustrating going to use a set which turned out to be flat. Even worse, if a set had fully discharged, even after investing in some expensive battery chargers they would then fail to charge, and be effectively useless. I then discovered that battery technology had moved on and low self discharge batteries had become available, which seemed to be the answer to my problems. Up until recently I had no real way of objectively testing rechargeable batteries, but after a failure of one of my Ansmann chargers I did a lot of research to look for a replacement. I bought the very impressive Maha (Powerex) MH-C9000 charger which allows control of charging and discharge rates; most importantly it is able to give the capacity of each battery. It was this purchase that gave me the inspiration for writing this review.
Introduction
Low Self Discharge batteries (LSD) are a development from standard nickel metal hydride (NiMH) batteries. They are ideal for digital photographers and offer some real advantages. The most significant ones in my view are:
1) They will keep their charge when stored for a long time. Typically, the battery capacity will remain around 90% after six months and 80% after 12 months. Remember, standard NiMH will continuously discharge after charging when not in use.
2) LSD batteries have a flatter discharge curve under load which gives longer effective use when compared to a standard NiMH battery (assuming like for like capacity).
3) LSD batteries are supplied from new charged, so you can use them straight away; no delays while charging them.
However, it is not all good news. LSD batteries do have disadvantages when compared to normal NiMH batteries:
1) The maximum capacity of an AA sized LSD is lower. Currently, approx 2000mAh (mAh = milli-Ampere hours) is the largest capacity available. Standard NiMH batteries are available with capacities greater than 3000mAH.
2) Standard NiMH batteries are generally cheaper, but there are some fantastic deals to be had with LSD batteries.
Introduction
