Go Back   Olympus UK E-System User Group > Cameras, lenses and system accessories > Camera conference > Olympus E-450
Reply
Thread Tools Display Modes
  #1
Old 8th July 2012
ChrisF
Guest
Posts: n/a
Flash
Sorry, I'm new to the E-450, trying to work out how to turn built in flash off.
  #2
Old 8th July 2012
Robusto's Avatar
Robusto Robusto is offline
Full member
Liked 0 Times in 0 Posts
Send a message via MSN to Robusto
Re: Flash
to turn off flash go into your flash mode setting and select the option with a circle and a flash in the middle that will turn it of
__________________
To me, The goal is to move people, to make people think, but never, never at the expense of the person you're photographing. To laugh with, yes - but never to laugh at. - Lord Snowdon
Martyn
Olympus E30, HLD4 Grip E520 E300 HLD3 Grip, Pen E-PL1 Zuiko m14-42mm
Zuiko OM 28mm 2.8, 50mm 1.8 , 80-200mm
ZD 14-42mm, 14-45mm, 14-54mm, 40-150mm ,50-200mm , 70-300mm, 35mm Macro , EX-25
Sigma 50-500mm To be Obtained
Olympus FL36R ;Metz Flash 28AF-30
http://cannoncannonphotography.webs.com/
  #3
Old 8th July 2012
ChrisF
Guest
Posts: n/a
Re: Flash
thanks for that but it rather supposes that I know how to get to my flash mode setting!
  #4
Old 8th July 2012
PeterBirder's Avatar
PeterBirder PeterBirder is offline
Senior Member
Liked 797 Times in 466 Posts
Re: Flash
Hi Chris.
You need to go to the "Super Control Panel" by pressing the Info button (Handbook p.7/p.28). Select the Flash settings icon. The section of the handbook which starts on p.66 explains what all the various flash modes do. You will want to select Flash Off and when you do this the icon on the super control panel will turn to a flash symbol with a diagonal line through it.
Regards.
__________________
OM1n, OM 50mm f1.8.
  #5
Old 8th July 2012
Senior Member
Re: Flash
Hi Chris.
As you are new to the e-450 you will find Andrezej Wrotniak's site www.wrotniak.net useful.
His article on setting up the e-410/e510 is equally applicable to your e-450 and gives a much clearer explanation of what many of the settings actually achieve etc. than the Olympus handbook. This will give you a good starting point for getting the best from your camera.
The link to this article is www.wrotniak.net/photo/43/e510-sett.html
Regards.
__________________
OM1n, OM 50mm f1.8.
  #6
Old 8th July 2012
ChrisF
Guest
Posts: n/a
Re: Flash
am obviously thick but can't get anywhere with the info button and the other answer leads me to something which says he keeps his flash on all the time
  #7
Old 8th July 2012
Senior Member
Re: Flash
Strange.
What comes up on the screen when you switch the camera on?
__________________
OM1n, OM 50mm f1.8.
  #8
Old 8th July 2012
ChrisF
Guest
Posts: n/a
Re: Flash
a kind of menu which shows current settings but no way to move between things. Now I thin I've buggered it, how do you reset to standard?
  #9
Old 8th July 2012
Senior Member
Re: Flash
Don't worry. That's the super control panel.
Press the OK button in the middle of the arrow pad to the right of the screen and one of the boxes will turn yellow.Use the arrow pad to select the Flash symbol which is on the left below the ISO box. Press OK again and a row of options will be displayed, the Flash Off option is the right hand one on the top row. Use the arrow pad to highlight this option and press OK again. You should now have switched off the Flash.
Regards.
__________________
OM1n, OM 50mm f1.8.
  #10
Old 8th July 2012
IainMacD's Avatar
IainMacD IainMacD is offline
Full member
Liked 789 Times in 228 Posts
Re: Flash
My advice would be to leave the flash on Auto using the method described above by Peter and then go into the Menu system and find the Auto Pop up setting (see page 88 of your manual) and turn it to off. When you want the flash just press the button on the left shoulder to manually release the pop-up.
__________________
Iain
E-M5 II, E-M1, 7.5, 8-18, 12-40, 25, 40-150, 45, 60, 300
Website
  #11
Old 8th July 2012
IainMacD's Avatar
Full member
Re: Flash
To turn off the Auto Pop-up:
Press Menu
Press down arrow until Custom Menu E is highlighted
Press right arrow
Press down arrow to highlight Auto Pop-up
Press right arrow
Press up arrow to select off
Press OK
Press Menu to get back to the super control panel menu
__________________
Iain
Website
  #12
Old 8th July 2012
ChrisF
Guest
Posts: n/a
Re: Flash
all these sound great but I just can't seem to get to the menus you guys talk about. and I can't make head nor tail of the manual
  #13
Old 8th July 2012
Senior Member
Re: Flash
Quote:
If the "menu" that comes up when you switch on looks like that on page 7 of the manual then you have the "Super Control Panel" and then the instructions in my last post should work.
Don't give up we'll get you there.
__________________
OM1n, OM 50mm f1.8.
  #14
Old 8th July 2012
IainMacD's Avatar
Full member
Re: Flash
Apologies I missed a step out, after pressing the menu button (2nd from bottom to left of screen) press the down arrow 3 times to get to the spanner 1 menu and then click the right arrow and the as stated before:
Press right arrow
Press right arrow
Press OK
__________________
Iain
Website
  #15
Old 9th July 2012
ChrisF
Guest
Posts: n/a
Smile Re: Flash
Brilliant, got it and it works, thanks everso Iain
The Following User Says Thank You to For This Useful Post:
IainMacD (9th July 2012)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
flash 250 m-888-khan For sale or wanted small ads 1 8th July 2012 03:12 AM
Flash Mob Graham_of_Rainham The lounge 3 15th May 2012 08:15 AM
Off camera flash and alternate flash units (speedlights) to the FL's theMusicMan Flash 5 18th September 2010 07:01 PM
T32 Flash ICR Olympus E-500 3 23rd March 2010 08:23 AM
FS-FR1 Flash Adapter Ring (for ring flash) Naughty Nigel For sale or wanted small ads 2 17th February 2009 09:59 PM
