Go Back   Olympus UK E-System User Group > Cameras, lenses and system accessories > Camera conference > Micro Four Thirds > Olympus OM-D E-M1 Mark II
Olympus OM-D E-M1 Mark II The second Micro Four Thirds camera that offers phase detect focusing so you can use Four Thirds DSLR lenses normally as well a Micro Four Thirds lenses.
Reply
Thread Tools Display Modes
  #16
Old 3rd March 2017
Clockwork Donkey Clockwork Donkey is offline
Full member
Liked 29 Times in 11 Posts
Re: New Firmware 1.1 Released
LR still opens the RAW files after the firmware update, but as the PP has stated there is only provisional support at present.
  #17
Old 3rd March 2017
Grumpy Hec's Avatar
Grumpy Hec Grumpy Hec is offline
Grumpy Member
Liked 447 Times in 210 Posts
Quote:
Originally Posted by pdk42 View Post
The fact they Oly have raced out an update with a single change tells me that this is an urgent patch to fix a problem that they deem sufficiently serious to go through the release update process. It would be really interesting to know what the problem is that they've fixed. Has anyone noticed anything odd about raw files?
Have had a few incidents of the card being read for ages when switching on and also if I've removed/reinserted the card. I've put it down to the SD card but who knows.
I have also had problems with both LR and PS trying to stitch a panorama. Just says unexpected error and leaves it at that.
Both of these could logically be down to RAW file problems but unproven as yet.
Hec
__________________
  #18
Old 3rd March 2017
Gwyver's Avatar
Gwyver Gwyver is offline
Full member
Liked 356 Times in 164 Posts
Quote:
Originally Posted by Maria View Post
I've just updated my camera to the latest firmware. My update worked OK and claimed to backup and restore all my settings, however C1, C2 and C3 are all now set to 1/320 and f4 - all were different before the update. The other custom settings for these seem OK - as far as I can tell - though I've not trawled through all the menus to see if anything else is missing (that is, if I can remember what was there).
Before doing the update, I also used the updater to save my settings - I've also tried loading this earlier version too, with exactly the same results. Has anyone come across anything else not saved?
Maria,
My experience was similar - except it changed to shutter = 1/400 and aperture = F4.5
I also noticed that the Exp Comp setting which I have specified for the C1, C2 & C3 modes had reverted to 0.
I surmised that post-update settings reload may use the shutter, aperture, ExpComp values that applied to Manual Mode prior to the update.
However, I then reloaded the Camera settings from a previously created Settings file but this also failed to re-establish my previous Custom mode shutter/Aperture & ExpComp values.
So this does seem like a bug/oversight in the v2 Camera Updater program. I shall email Olympus tech support regarding this issue.
__________________
  #19
Old 6th March 2017
Gwyver's Avatar
Full member
As mentioned above, I contacted Olympus support noting:
"I have recently updated my camera firmware to v1.1.
On completion of this update the Olympus CameraUpdater program re-applied my Main & Custom settings values.
However the Manual mode shutter speed, lens aperture & Exp Comp. values that I had previously saved for each C1, C2, & C3 configuration were NOT restored.
Is this a CameraUpdater feature or a bug?
If intentional this is a serious shortcoming which reduces the benefit of the Save/Restore settings feature in CameraUpdater v2."
The repsonse from Olympus was:
"You are very correct in your thinking. The restore function works with all pre-programmed settings.
A pre-programed setting does not include dial-in settings like shutter speed and Aperture."
Given that the camera does remember the 'dial-in settings' which have been assigned for each Custom mode (and restores them following Power-off & on), it seems illogical that these values aren't included in the settings file created by Camera Updater.
__________________
  #20
Old 6th March 2017
Goon525 Goon525 is offline
Full member
Liked 9 Times in 7 Posts
I agree with you, Chris.
  #21
Old 6th March 2017
Maria Maria is offline
Full member
Liked 18 Times in 9 Posts
It doesn't make sense - the whole idea of having C1 - 3 is to save settings that can then be quickly accessed - including preferred aperture and speed. I've now contacted support too - maybe if enough people complain, they'll change it.
  #22
Old 7th March 2017
Full member
This is the response I got from Olympus support - it looks like they have listened...
At this time I have to advise that the retention of settings applies to only certain functions (see p 165 of your manual) such as the specialist functions of the camera's buttons. Shutter speed and aperture functions are not retained, however I am reliably informed that our R&D department are addressing this issue after feedback from users and are planning to implement the update required soon. I do apologise for the inconvenience in the meantime.
The Following 4 Users Say Thank You to Maria For This Useful Post:
c12402 (7th March 2017), cliff (7th March 2017), Grumpy Hec (11th March 2017), Gwyver (7th March 2017)
The Following Users Liked This Post:
drmarkf (18th March 2017), Gwyver (7th March 2017)
  #23
Old 18th March 2017
drmarkf's Avatar
drmarkf drmarkf is offline
Full member
Liked 816 Times in 451 Posts
Fuji users drone on for hours about how responsive the manufacturer is to user input and how they extend the functionality of earlier bodies with FW updates, but Olympus nowadays excel in these regards.
(Don't ask about how responsive Sony are, by the way: their contributions consist solely of releasing useless apps in the app-alling and virtually unusable PlayMemories store... )
__________________
Olympus E-M1ii x2: 7-14, 12-100, 40-150, 45, 60, 75, 300, 1.4tc.
Panasonic 12-35, 15. Samyang 7.5 fisheye.
Assorted legacy lenses, plus a Fuji X70.
The Following User Liked This Post:
wornish (18th March 2017)
  #24
Old 18th March 2017
pdk42's Avatar
pdk42 pdk42 is offline
Full member
Liked 3,749 Times in 1,263 Posts
Quote:
When I had the A7Rii I was interested in an app from the Sony store that seemed to do what the Livetime function does on the Olympus cameras. I was amazed to discover that it only worked on the A7s. I did download (i.e. buy) one of the other apps but was very disappointed. Apps run as little standalone programs meaning that many of the usual functions of the camera no longer work. I quickly came to the view that it seems a nice concept but the implementation is pants.
On top of that, I suspect that my persona was stolen by Russian hackers from the PlayMemories store
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Firmware v4.3 released Olybirder Olympus OM-D E-M1 32 24th January 2017 11:44 AM
Firmware v4.1 Released CJJE Olympus OM-D E-M1 12 6th February 2016 09:37 PM
E-M1 firmware 3.1 (& E-M5 Mk II) released Ross the fiddler Olympus OM-D E-M1 28 30th June 2015 11:09 AM
E-M1 firmware 1.4 is released pault Olympus OM-D E-M1 55 8th June 2014 08:36 AM
EC-20 Firmware V1.1 released j.baker General accessories 1 19th December 2007 11:15 AM
The Write Technology Ltd, 2007-2017, All rights reservedAd Management plugin by RedTyger
