Reply
Thread Tools Display Modes
  #1
Old 21st November 2016
OM USer's Avatar
OM USer OM USer is online now
Full member
Liked 912 Times in 636 Posts
Question Please Explain MySets on PASM Dial
I only have an E-M5 Mk1 and an E-PM2 but I am trying to understand how MySets work when assigned to a position on the PASM dial on the E-M5 MK II and other cameras that have this function. The manuals for these cameras is woefully short on any meaningful description.
On the E-M5 I can set up and use the 4 MySets by calling up the menu and I have no problem with this. If I am in A (aperture priority) mode and switch to S (Shutter priority) mode then all my settings other than aperture/shutter (the thing I am changing) priority stay the same. If I make a temporary setting change and do not update the MySet then than temporary change is still preserved when the PASM dial is rotated.
My understanding is that on cameras where a position on the PASM dial can be assigned a MySet (whether it be ART, iAuto, or even C1, C2, or C3 on those dials that have it) then the MySet settings also include whether the camera was in P (Program), A (aperture priority), S (shutter priority), or M (manual) mode when the settings were saved. Also, that when selecting that MySet by rotating the PASM dial to the position where that MySet has been assigned, the mode (P, A, S, or M) that was saved is restored along with the other settings in the MySet.
Now, assuming that you have rotated the PASM dial to a position that has a MySet assigned to it and the camera is now using the MySet settings you want, how do you then change just the shooting mode (P, A, S, or M)?
On the E-M5 MK 1 I would rotate the PASM dial but on a camera where MySets are assigned to PASM dial positions you could end up going through another assigned MySet and changing just more than the shooting mode.
You could of course go to your required P, A, S, or M position and recall the MySet from the menu but this would loose any temporary setting you had changed but not saved whilst the PASM dial was in a "MySet" assigned position.
It looks like recalling a MySet from an assigned position on the PASM dial sets the shooting mode (P, A, S, or M) but recalling the MySet from menu doesn't and the shooting mode stays as it was.
It just doesn't seem logical.
I have tried searching this forum and tried using google (other search engines are available) but have found no explanation as to how MySets, the PASM dial, and shooting modes actually interact. Can anyone help please?
__________________
Lenses (M.Zuiko Digital): 7-14mm/F2.8, 12-40mm/F2.8, 40-150mm/F2.8+TC1.4x, 12-50mm/F3.5-6.3, 14-42mm/F3.5-5.6 EZ, 75-300mm/F4.8-6.7 Mk1, 12mm/F2, 17mm/F1.8
If you learn something new each day then that is not a day wasted.
  #2
pdk42's Avatar
pdk42 pdk42 is offline
Full member
Liked 4,126 Times in 1,372 Posts
Re: Please Explain MySets on PASM Dial
Quote:
You can't!
The camera remembers the settings in the PASM settings separately to any MySets that you happen to pass through on the way.
I think that's how it works.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Renaming Mysets fotofundi Olympus OM-D E-M1 2 11th August 2016 09:54 AM
mysets.... ste_p0270 Olympus OM-D E-M5 2 26th October 2014 08:08 PM
Tweaking MySets Bengeo Olympus OM-D E-M1 6 15th April 2014 06:17 PM
HELP! Here's a puzzler for you - No AF in PASM? DJMC Camera conference 4 13th August 2012 09:21 AM
What does PASM stand for? snaarman The lounge 23 14th February 2012 03:40 PM
