Reply
Thread Tools Display Modes
  #1
Old 22nd September 2016
justa1972 justa1972 is offline
Full member
Liked 1 Time in 1 Post
Shutter shock?
Hello
After some advice please
I am looking at switching to m43 and have narrowed it down to the omd em 5 mk ii or the new Panasonic g80 - I am leaning towards the Olympus die to the superior jpegs.
Should I be concerned with shutter shock?
Thanks
  #2
pdk42's Avatar
pdk42 pdk42 is offline
Full member
Liked 4,129 Times in 1,374 Posts
Re: Shutter shock?
Quote:
Originally Posted by justa1972 View Post
Hello
Thanks
Afaik, neither of these cameras suffers from shutter shock. There are plenty of u43 cameras in the part that did, but I think they've now sorted the issues. First curtain electronic shutter is a big help.
__________________
  #3
Ian's Avatar
Ian Ian is offline
Administrator
Liked 1,100 Times in 525 Posts
Re: Shutter shock?
The Panasonic has a completely new shutter unit in order to solve the problem of shutter shock with previous models. The E-M5 Mark II has one of the quietest and vibration-free shutters of any system camera on the market - shutter shock is not a problem at all. You can also use silent (no mechanical shutter) shutter mode so there will be no shutter shock at all (both cameras have this).
__________________
  #4
Full member
Re: Shutter shock?
Plenty of evidence of shutter shock in the em5 mk ii - even on this website
http://e-group.uk.net/forum/showthread.php?t=36831
  #5
Ricoh Ricoh is offline
Full member
Liked 1,318 Times in 801 Posts
Re: Shutter shock?
I can't remember the precise cause (other than the obvious that a live view sensor requires the shutter to slam shut just prior to exposure) but from first principles it would appear that image stabilisation tends to exacerbate the situation. Dump image stabilisation and all should be fine.
__________________
  #6
pdk42's Avatar
Full member
Re: Shutter shock?
Quote:
Steve - I did a lot of testing and research on shutter shock back in the day that I had an E-P5 (now that was a camera with BAD shutter shock!). I concluded that IBIS was not an endemic and reproducible problem. I have evidence of it causing problems, but it's infrequent and the result is not at all the same as shutter shock.
This is understandable for two reasons:
- The periodicity of shutter shock is a lot shorter (higher frequencies) than IBIS is designed to handle - i.e. IBIS won't try to correct shutter shock.
- Even when IBIS is off, the sensor is still suspended by the voice coils, so if lack of rigidity is the issue, turning it off won't make much difference.
OTOH, shutter shock was fairly easy to reproduce on the E-P5 and the fix that Olympus did to introduce a short delay (20ms) between the first curtain opening and exposure starting ( so-called 0s anti-shock) fixed it entirely.
I've done tests on other cameras and this is my own view:
- E-M5: no appreciable issue. Can sometimes occur with some lenses (the 75mm seemed to be the one that did it the most).
- E-M1: suffers noticeable shutter shock unless you use the 0s delay
- E-M10: slight blurring on some lenses. Fixed entirely by the 0s anti shock mode
- GX7: slight bit easily reproducible blurring due to shutter shock. No fix available.
- E-PL5: slight blurring with some lenses. No fix available.
Remember that shutter shock only happens at certain shutter speeds - usually in the 1/100s range or thereabouts.
__________________
The Following 2 Users Say Thank You to pdk42 For This Useful Post:
OM USer (25th September 2016), Ricoh (22nd September 2016)
  #7
Full member
Re: Shutter shock?
Thanks Paul, it's coming back to me now that you've refreshed my memory. Obviously quite a complex situation. It doesn't surprise me that the impulse shock generated by the shutter rapidly decelerating produces high frequency components outside the bandwidth of ibis. Ibis after all is designed to discriminate against human motion and not against fast edge accelerations.
__________________
  #8
Old 20th March 2017
Harold Gough Harold Gough is offline
Full member
Liked 1,792 Times in 998 Posts
Re: Shutter shock?
Quote:
I have never experienced it on the EM-1 but it is present on my A7R.
Harold
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Anti Shutter Shock Settings Philn67 Olympus OM-D E-M10 3 28th June 2015 03:20 PM
Shutter Shock :( snerkler Olympus OM-D E-M5 Mark II 36 18th March 2015 12:56 PM
E-M1 firmware v1.3 - shutter shock & image sharpness Angus Olympus OM-D E-M1 26 17th September 2014 03:20 PM
Shutter Shock and the E-M5 Zuiko Olympus OM-D E-M5 24 21st June 2014 09:23 AM
Shutter shock mike_j Olympus Pen E-P5 8 25th November 2013 06:26 PM
