Reply
Thread Tools Display Modes
  #1
Old 30th June 2016
xfroggerx xfroggerx is offline
Junior Member
Liked 0 Times in 0 Posts
Question Green squiggly lines in the EVF.
I was on a trip to London and these green squiggly, worm like, lines suddenly appeared in the EVF. When I returned to home I sent it in for repair. 5 months later the same problem. And again had to send it back 5 months after that for the same problem. It only effects the EVF. Has anyone else had this problem?
  #2
Old 30th June 2016
drmarkf's Avatar
drmarkf drmarkf is offline
Full member
Liked 928 Times in 519 Posts
Re: Green squiggly lines in the EVF.
What did they say the problem was due to? What did they replace? Are the lines stationary or do they move? Have you left the camera in the sun for any prolonged period?
There is a reported issue with VF damage from prolonged direct sunlight: it can happen with several makes of camera, but it may be that Oly are more susceptible for some reason.
We need more information from you, really.
__________________
Olympus E-M1ii x2: 7-14, 12-100, 40-150, 45, 60, 75, 300, 1.4tc.
Panasonic 12-35, 15. Samyang 7.5 fisheye.
Assorted legacy lenses, plus a Fuji X70.
  #3
Old 30th June 2016
Ross the fiddler's Avatar
Ross the fiddler Ross the fiddler is offline
Full member
Liked 1,414 Times in 851 Posts
It is also when the dioptre adjustment is +2 (or something like that) that direct sunlight entering the EVF is concentrated on the display & burning it. In other words, if you're out on a sunny day with the camera hanging down (with a long lens) from a neck strap or on a sling strap, it will likely get the sun in it which can cause that problem & possibly why it occurred again. Having some sort of cover shield would be beneficial. Really, it should have some sort of auto closing shield that only opens when the EVF Eye Sensor is active, i.e. when looking into it. This might be possible with a blanking LCD panel near the external lens but obviously they haven't yet decided it is needed yet. I have also heard of a filter (film) being used on the external glass to help. Something like that reflector film perhaps. It should be possible to see through it once the eye cup is shielded from external light when looking into it.
__________________
Lenses: M.ZD12-40mm f2.8 PRO Lens, M.ZD40-150mm f2.8 PRO Lens with MC-14, M.ZD12-50, M.ZD60 Macro, M.ZD75-300 Mk II, MMF-3, ZD14-54 II, Sigma 150mm F2.8 APO Macro DG HSM.
The Following User Says Thank You to Ross the fiddler For This Useful Post:
Loup Garou (2nd July 2016)
  #4
Old 2nd July 2016
Loup Garou's Avatar
Loup Garou Loup Garou is offline
Full member
Liked 48 Times in 41 Posts
But the EVF has a prominent rubber hood over it and this should protect it from angular sun rays when the camera hands around your neck with the big lens tipping it forwards?
  #5
Old 2nd July 2016
Full member
Quote:
It's not the angular sun rays that is the problem. It's the direct sun rays on the sensor that does the damage & it usually happens as the camera is being carried.
__________________
  #6
Old 2nd July 2016
Loup Garou's Avatar
Full member
I usually carry my camera and lenses in a bag and take them out as necessary. On holidays, I usually take only the Olympus 12-50mm lens with the OMD EM5II and for that I have a Lowepro Cirrus TLZ 25 that is ideal to sling around one's neck. That case is very snug and also perfect for those using an Olympus camera with the 14-150 "all in one" lens on trips. Even has space for the hood.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The Green, Green Grass of Home pandora Foto Fair 4 20th May 2016 06:54 PM
Lines pdk42 Foto Fair 16 14th March 2015 11:38 PM
lines banjukes Foto Fair 14 26th May 2014 10:18 PM
Railway lines Floribunda Looking for improvement 21 20th January 2012 11:11 PM
Tag lines? Adam Easton The lounge 4 29th August 2011 10:12 PM
