Reply
Thread Tools Display Modes
  #16
Old 23rd June 2016
drmarkf's Avatar
drmarkf drmarkf is offline
Full member
Liked 923 Times in 517 Posts
Re: Arca Swiss L plate
The Amazon-sourced L-bracket has arrived, and it's OK. Not perfect, but certainly OK, and it fits very securely allowing good access.
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
The only area that isn't perfect is the two allen bolts holding the right hand grip to the bottom plate: they weren't very tight, and using the supplied small allen key to give them a bit more torque did more damage to their heads than I'd really like. I don't rate this as much of an issue: the grip doesn't improve security of the plate on the camera, and I'm actually tempted to remove it to reduce size and weight.
Anyway, the larger gauge allen screws holding the short arm of the plate to the base are properly tight, and they are the same gauge as the tripod screw in the base (which usefully also has a 'coin' slot).
The whole ensemble with camera fits my Markins Arca Swiss ballhead perfectly, and so far I rate it well worth 25 quid.
Now I just need the height extender...
__________________
Olympus E-M1ii x2: 7-14, 12-100, 40-150, 45, 60, 75, 300, 1.4tc.
Panasonic 12-35, 15. Samyang 7.5 fisheye.
Assorted legacy lenses, plus a Fuji X70.
The Following User Liked This Post:
Ross the fiddler (23rd June 2016)
  #17
Old 7th July 2016
drmarkf's Avatar
Full member
The extender clamp arrived yesterday and seems absolutely fine. The clamp mechanism is firm and wobble-free, the finish and fit are great and there's plenty of space to loop the remote cable through.
It all looks a bit Heath-Robinson, but certainly solves my needs for a very fair price. Thanks!
It would be a lot simpler if someone produced a right-angled Olympus cable connector, of course...
__________________
  #18
Old 7th July 2016
David M's Avatar
David M David M is offline
Full member
Liked 1,293 Times in 792 Posts
As this thread has been resurrected I should add that I removed the safety stops from my universal L brackets. For me they defeat the purpose of an L bracket if you have to fully open the clamp to swap between landscape and portrait framing.
__________________
The Grumpy Snapper blog or follow me on Instagram.
  #19
Old 7th July 2016
Ross the fiddler's Avatar
Ross the fiddler Ross the fiddler is offline
Full member
Liked 1,402 Times in 848 Posts
Yes, a right angle plug/cable would be nice.
Quote:
Until you forget to tighten the clamp properly & the camera slips out.
__________________
Lenses: M.ZD12-40mm f2.8 PRO Lens, M.ZD40-150mm f2.8 PRO Lens with MC-14, M.ZD12-50, M.ZD60 Macro, M.ZD75-300 Mk II, MMF-3, ZD14-54 II, Sigma 150mm F2.8 APO Macro DG HSM.
  #20
Old 7th July 2016
David M's Avatar
Full member
Quote:
I don't think any of the custom plate makers had safety stops when I started using the Arca Swiss system. I used my Kirk telephoto plates for a couple of decades without safety stops and most of my plates still don't have them.
__________________
  #21
Old 7th July 2016
Full member
We used to drive cars without seat belts too. And power tools just had plain on off switches, but thankfully we have fail safe or safety etc included in designs now.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Clamp for Arca-swiss lens plate, advice please!. Thomas Westhead General accessories 5 19th June 2014 09:58 PM
Arca swiss tripod head for RRS L-plate (OM-D EM1) dkayuk General accessories 11 31st January 2014 10:52 PM
OM-D Arca-Swiss L-bracket options? drmarkf Accessory talk 3 2nd June 2013 02:32 PM
For sale Wimberley P-10 Arca-Swiss QR plate (fits 150mm f2) drmarkf For sale or wanted small ads 0 11th December 2012 06:21 PM
Arca-Swiss plates for 150 f2 and 50-200? drmarkf General accessories 4 3rd December 2009 08:17 PM
