Reply
Thread Tools Display Modes
  #1
Old 17th June 2016
drmarkf's Avatar
drmarkf drmarkf is offline
Full member
Liked 923 Times in 517 Posts
Arca Swiss L plate
Anyone know of an Arca Swiss compatible L plate for the M5 II that allows access to the wired remote socket?
Thanks.
__________________
Olympus E-M1ii x2: 7-14, 12-100, 40-150, 45, 60, 75, 300, 1.4tc.
Panasonic 12-35, 15. Samyang 7.5 fisheye.
Assorted legacy lenses, plus a Fuji X70.
  #2
Old 17th June 2016
Ross the fiddler's Avatar
Ross the fiddler Ross the fiddler is offline
Full member
Liked 1,401 Times in 847 Posts
Re: Arca Swiss L plate
Quote:
Thanks.
Check out this search. http://www.ebay.com/sch/sis.html?_nk...5II+Arca+Swiss
This one might be a good option.
You would also need an add on stand piece (can't remember what it's proper name is) to allow the cable to be in place & I will look through my past orders to point you to a suitable unit later.
__________________
Lenses: M.ZD12-40mm f2.8 PRO Lens, M.ZD40-150mm f2.8 PRO Lens with MC-14, M.ZD12-50, M.ZD60 Macro, M.ZD75-300 Mk II, MMF-3, ZD14-54 II, Sigma 150mm F2.8 APO Macro DG HSM.
The Following User Says Thank You to Ross the fiddler For This Useful Post:
drmarkf (18th June 2016)
  #3
Old 18th June 2016
Full member
This is the additional height extender for portrait position which allows room for a remote cable to be attached that I bought & works quite well.
Found here. http://www.ebay.com.au/itm/Improved-...sAAOSwpdpVY9tr
I think it is a much better price than you'd have to pay for that Really Right brand.
__________________
  #4
Old 18th June 2016
drmarkf's Avatar
Full member
Aha! Yes, that extender piece will do it, and it will also work with my E-M1's RRS L-plate I'm sure. Brilliant. thanks.
It's also available via UK eBay and free shipping claims it will arrive by the end of July, which will be in time for my next significant landscape photo trip.
Does it give enough clearance for the RM-UC1 cable?
I much prefer a wired release over the smartphone app since I'm not keen on running down the phone battery if I'm out on the hills all day.
__________________
  #5
Old 18th June 2016
Full member
I hope it would come sooner than the end of July though.
__________________
  #6
Old 18th June 2016
drmarkf's Avatar
Full member
They usually underpromise and overdeliver in my experience.
I've also ordered one of the L plates from UK Amazon which will be here next week: it will be interesting to compare it with the E-M1's RRS L plate.
__________________
  #7
Old 18th June 2016
Full member
I think the E-M1's RRS L plate is over priced & went for the iShoot branded one instead at a much cheaper price. As long as you're buying from a highly rated seller with good feedback (& only negatives from whingers).
__________________
  #8
Old 18th June 2016
drmarkf's Avatar
Full member
Quote:
Yes, I agree. I got the RRS from someone on here as I recall, for a very fair price.
I've bought plates over the years from both expensive (RRS, Kirk and Markins) and cheaper (JJC and similar) sources and I've never had a problem with either. I do follow your advice about choosing a cheaper seller, of course!
I'm sure it's more significant where there's more engineering involved in what you're buying: joints, hinges, balls, sliders etc and I'm generally happy to pay top whack for that sort of stuff. In my experience again, it's best to buy those things well and only once...
__________________
  #9
Old 18th June 2016
Full member
BTW, the height adaptor needs to be high enough for the length of the moulded plug on the remote cable (hanging out of the side of the camera). I bought this one & it isn't high enough.
__________________
  #10
Old 18th June 2016
drmarkf's Avatar
Full member
Yes, I guessed as much.
The one you recommended is a bit ungainly-looking, but should do the job well.
BTW does anyone know if you can get extension cables for the RMUC-1 and/or adapters that have smaller plugs or else a 90 degree bend plug? I've had a search and can't find anything.
__________________
  #11
Old 18th June 2016
Full member
We wish!
__________________
  #12
Old 18th June 2016
David M's Avatar
David M David M is offline
Full member
Liked 1,293 Times in 792 Posts
I've no complaints about the cheaper Chinese plates and clamps, the finish is better than some of the name brand items I've got. The nice thing about them is they're cheap enough that when you start filing/drilling/tapping them you don't worry about it.
Having a wide variety of plates I only use screw locking clamps, the lever types weren't available when I started using the system and given the issues some users have had with the lever types I avoid them.
__________________
The Grumpy Snapper blog or follow me on Instagram.
The Following User Liked This Post:
Ross the fiddler (18th June 2016)
  #13
Old 19th June 2016
Walti Walti is offline
Senior Member
Liked 925 Times in 367 Posts
At the risk of hi-jacking the thread, I bought a cheap "Arca Swiss" ball head to stick on top of my monopod, for use with the 300... the system seems to work very well, but there's no form pf security, if the clamp screw gets accidentally loosened... the lens and camera will slide straight out - how do you secure it better?
__________________
Some Olympus stuff
I didn't get where I am today...
  #14
Old 19th June 2016
drmarkf's Avatar
Full member
Quote:
No hijack at all!
I've linked here to one of the Markins ballheads that has an image showing the main safety feature on many ballheads - a sprung button that presses upwards from the clamp base and usually engages in one of the cutouts in the QR plate:
http://www.photoproshop.com/Tripod-A...vf0fc2fj5g3ji0
Some heads have got a button or lever on the side or bottom that withdraws the button, while with others you need to push it down with a finger or stick through a hole in the plate.
Hope that makes it sort-of clear.
__________________
  #15
Old 19th June 2016
David M's Avatar
Full member
Some plates have safety stops on the ends, stopping them sliding fully out of the clamp. I used Kirk telephoto plates for a couple of decades without safety stops. You have to get used to making sure the clamp is tight before you throw the tripod over your shoulder.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Clamp for Arca-swiss lens plate, advice please!. Thomas Westhead General accessories 5 19th June 2014 09:58 PM
Arca swiss tripod head for RRS L-plate (OM-D EM1) dkayuk General accessories 11 31st January 2014 10:52 PM
OM-D Arca-Swiss L-bracket options? drmarkf Accessory talk 3 2nd June 2013 02:32 PM
For sale Wimberley P-10 Arca-Swiss QR plate (fits 150mm f2) drmarkf For sale or wanted small ads 0 11th December 2012 06:21 PM
Arca-Swiss plates for 150 f2 and 50-200? drmarkf General accessories 4 3rd December 2009 08:17 PM
