Reply
Thread Tools Display Modes
  #1
Old 17th June 2016
PaulB PaulB is offline
Full member
Liked 7 Times in 6 Posts
Focus bracketing won't work with flash (5mkii)
I've been trying focus bracketing and have just discovered if I turn focus bracketing to "on" the shutter release frame rate auto sets to silent, high and I can't change it.
The problem is when the silent shutter is enabled it disables flash!
Is this affecting anyone else or just me?? Am I missing something??
Seems daft as there's a setting in the focus bracketing set up for flash recharge time!
  #2
Old 17th June 2016
PeterBirder's Avatar
PeterBirder PeterBirder is offline
Senior Member
Liked 801 Times in 468 Posts
Re: Focus bracketing won't work with flash (5mkii)
I have the E-M10 MKII which has Focus Bracketing and it does the same. What you have to do is, when it has disabled the flash select Flash on the SCP and you will see it will enable you to select Manual Flash and adjust its power.
I presume this has come about because Focus Bracketing uses Silent Shutter/Sequential mode which cannot normally be used with flash and Olympus have forgotten to make it select Manual Flash automatically when you use Focus Bracketing + Flash.
Regards.
__________________
OM1n, OM 50mm f1.8.
The Following User Says Thank You to PeterBirder For This Useful Post:
OM USer (19th June 2016)
  #3
Old 17th June 2016
Full member
Thanks for the reply Peter.
I also asked the question on another forum and got a reply that the flash worked but at restricted speeds so had a play.
I originally tried with the supplied fl-lm3 flash but was unaware of the sequence you have posted and as it didn't work, i didn't try my Metz flash.
I have tried the Metz now though and it works in all modes apart from manual with focus bracketing on. Max sync speed is 1/20th second.
Thanks for your help.
  #4
Old 17th June 2016
Senior Member
Glad you got it sorted Paul.
I did look at the E-M5 MK II manual update for Focus Bracketing which says "For flash shooting set the shutter speed to 1/20th sec or slower" but that note doesn't appear in the E-M10 MK II manual.
Regards.
__________________
OM1n, OM 50mm f1.8.
  #5
Old 17th June 2016
Ross the fiddler's Avatar
Ross the fiddler Ross the fiddler is offline
Full member
Liked 1,414 Times in 851 Posts
That's all good to know, especially when the manual doesn't explain it well enough.
__________________
Lenses: M.ZD12-40mm f2.8 PRO Lens, M.ZD40-150mm f2.8 PRO Lens with MC-14, M.ZD12-50, M.ZD60 Macro, M.ZD75-300 Mk II, MMF-3, ZD14-54 II, Sigma 150mm F2.8 APO Macro DG HSM.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
EM1 Focus bracketing Graptolite Olympus OM-D E-M1 18 6th February 2016 05:28 PM
Focus stacking/bracketing (EM1 with v4 FW) benvendetta Olympus OM-D E-M1 4 6th February 2016 04:56 PM
focus bracketing/ staking IanB The lounge 9 29th January 2016 04:42 AM
Focus stacking and bracketing. Dave in Wales Olympus OM-D E-M1 0 16th September 2015 07:38 AM
Focus and bracketing E5 adam m lucas Olympus E-5 1 13th June 2011 04:14 PM
