Reply
Thread Tools Display Modes
  #1
Old 14th May 2015
Stuart444 Stuart444 is offline
Full member
Liked 2 Times in 2 Posts
Viewfinder eye cup
Does anyone know why the eyecup is removable? I found it easy to dislodge when taking it out of my rucksack and predictably I've just lost it. I'm wondering if using a small dab of superglue on the replacement might have any downside?
  #2
Old 14th May 2015
Wee man's Avatar
Wee man Wee man is offline
Senior Member
Liked 1,127 Times in 740 Posts
Re: Viewfinder eye cup
? So that you can fit differing models of eyecup.
__________________
Ed
What if the Hokey Cokey is what its all about?
  #3
Old 14th May 2015
Ross the fiddler's Avatar
Ross the fiddler Ross the fiddler is offline
Full member
Liked 1,401 Times in 847 Posts
Quote:
I wouldn't be doing that! Apart from voiding warranty, removing the eyecup to clean the glass is sometimes needed too. Also, if you damage the rubber you don't want to be extracting the old eyecup with a scalpel because you used superglue (or any other glue). If the rubber should come away from the eyecup frame, then removing the whole eyecup & re-gluing the rubber back onto the frame with a tiny bit of glue (but only when it is off the camera) by applying it with a small drop of glue on a pointed tool (too much might come from the tube of glue & spread everywhere) would be absolutely fine if done carefully.
__________________
Lenses: M.ZD12-40mm f2.8 PRO Lens, M.ZD40-150mm f2.8 PRO Lens with MC-14, M.ZD12-50, M.ZD60 Macro, M.ZD75-300 Mk II, MMF-3, ZD14-54 II, Sigma 150mm F2.8 APO Macro DG HSM.
  #4
Old 15th May 2015
Full member
I hadn't realised that other models of eyecup fit it as when searching for a replacement it's the only one I saw advertised for the M5ii. Do you know which other models fit it? I didn't find this one particularly useful, so I might try a different one if others will fit.
Yes, I suppose so, I don't want to risk invalidating the guarantee. I do wish it locked on a bit more securely, though.
I will have to modify my camera bag as it's the act of taking it in and out of the foam padding that causes it to be dislodged.
  #5
Old 15th May 2015
Full member
That's the same for medical conditions. People often worry about the symptoms & forget about the cause, so it is probably a very good idea to deal with the cause, of taking it out of your bag. I found the same problem & a bag that won't drag on protruding parts has got to be a better solution to start with.
As far as the eyecup is concerned, the standard EP-15 Eyecup only fits the E-M5 II along with the EP-16 large eyecup. I would be interested to know if they could physically fit on the E-M1, but may sit too high for proper access to the Accessories Port (between the EVF & hotshoe) as the E-M10 eyecup does on the E-M5.
__________________
  #6
Old 15th May 2015
Bikie John's Avatar
Bikie John Bikie John is offline
Full member
Liked 572 Times in 393 Posts
Interesting. I found wandering eyecups to be a problem with all my earlier Olys (E-1, E-3, E-5 and E-M5) but the E-M1 seems much better. So I thought they had fixed it, but it seems not if the E-M5 Mk II has reverted back to the norm.
  #7
Old 15th May 2015
greenguru's Avatar
greenguru greenguru is offline
Full member
Liked 81 Times in 29 Posts
I used to put a bit of blu-tac between the eyecup and camera on my E3 and never lost one.
  #8
Old 15th May 2015
OM USer's Avatar
OM USer OM USer is online now
Full member
Liked 912 Times in 636 Posts
Don't use superglue. A dab of nail polish is very effective and a lot easier to remove. Its also a good alternative to "threadlock" to stop small screws becoming loose where you have loosened them slightly on the bezel of your E-M5 Mk1 to stop it cracking.
__________________
Lenses (M.Zuiko Digital): 7-14mm/F2.8, 12-40mm/F2.8, 40-150mm/F2.8+TC1.4x, 12-50mm/F3.5-6.3, 14-42mm/F3.5-5.6 EZ, 75-300mm/F4.8-6.7 Mk1, 12mm/F2, 17mm/F1.8
If you learn something new each day then that is not a day wasted.
The Following 2 Users Say Thank You to OM USer For This Useful Post:
Imageryone (19th January 2016), Petrochemist (20th January 2016)
The Following Users Liked This Post:
Minniesmum (19th January 2016), raymondo (17th May 2015)
  #9
Old 17th May 2015
Anne Anne is offline
Full member
Liked 35 Times in 25 Posts
I used a glue dot on my EM-5 to hold a broken one in place. It worked quite nicely and was easily removable when it came to replacing it with a new one....which still comes off every time I put it in or take out of my camera bag
The Following User Says Thank You to Anne For This Useful Post:
The Following User Liked This Post:
  #10
Old 19th January 2016
Minniesmum's Avatar
Minniesmum Minniesmum is offline
Full member
Liked 17 Times in 9 Posts
I lost my eyecup for the V-F2 last year and have just ordered a new one. Very easy to do Going to follow a few suggestions on here to try to keep the new one for a bit longer !
__________________
https://www.flickr.com/photos/minnies_mum
  #11
Full member
Quote:
Just don't use super glue but something that can be removed later if needed. A small spot of contact adhesive applied with a tooth pick might also be one way of gluing things if needed.
BTW, if having taken the eyecup assembly (plastic & rubber) off the camera then a very small controlled amount super applied with a tooth pick can be used to glue the rubber back onto the plastic frame, but it must be dry before reattaching to the camera, otherwise the glue could get places you might wish it really hadn't.
__________________
  #12
Jim Ford Jim Ford is offline
Full member
Liked 817 Times in 536 Posts
I drilled and tapped the eyepiece for a small screw. The screw doesn't touch the camera body, but blocks the 'dovetail' preventing the eyepiece from sliding off. The screw can be removed for cleaning the eyepiece.
I'll post an image later.
  #13
Imageryone Imageryone is offline
Full member
Liked 564 Times in 336 Posts
Quote:
I use nail polish as well, works a treat and cleans off with a thumbnail
__________________
  #14
Full member
Here's the modification I made to the eyecup on my E5:
  #15
Full member
Cool Re: Viewfinder eye cup
Nice mod, I'm all for engineering solutions as I'm an engineer! I might give it a try. However I've not lost my replacement one yet, but I have changed my bag. I still could knock it off I guess when extracting it, but the side loading backpack I now have has no foam insert which my last bag had and was mainly the cause of the problem.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Sold VF2 viewfinder snaarman For sale or wanted small ads 3 5th March 2014 04:21 PM
For sale VF-2 viewfinder pdk42 For sale or wanted small ads 0 15th February 2014 11:51 PM
E-M1 viewfinder Bikie John Olympus OM-D E-M1 28 23rd December 2013 02:41 PM
vf2 vs vf3 viewfinder dkayuk Olympus Pen E-PL1 14 19th March 2012 07:33 AM
E-620 Viewfinder Snapper Olympus E-620/600 4 20th October 2011 09:44 PM
